Bad Stumble...Im at a loss
Old Jun 15, 2006 | 11:02 PM
  #46
HaynesFaithZ28's Avatar
Re: Bad Stumble...Im at a loss
Check your spark plug wires where they plug up to your optispark. Mine did the same after my rebuild and it ended up being the #8 cylinder was missing under loads because the wire was not pushed into the opti far enough. Good Luck.
Old Jun 18, 2006 | 08:29 PM
  #47
sean1997ws6's Avatar
Can you buy the OE coil ground wire anywhere?
Old Jun 19, 2006 | 10:16 AM
  #48
93yellowta's Avatar
I am having pretty much the same stumbling... I am pretty sure my fpr is leaking.. I can smell fuel in the vacumn line, my kirbin afpr came in today, I will put it on today and let you know if it helped with the stumbling...
Old Jun 19, 2006 | 10:18 AM
  #49
thansk man
Old Jun 19, 2006 | 10:38 AM
  #50
BLUETOPTA's Avatar
It sounds like you and I are having the same problems with our cars...
Old Jun 19, 2006 | 10:53 AM
  #51
when i put the engine back in we didnt have the braided coil ground wire so i just used a simple black ground wire. the weird thing is the car ran great with the old LT1. then as soon as i put the engine back in it had a slight high rpm miss just at about 5500, and then it all the sudden went into this. so i am just seeing if maybe something went.
Old Jun 19, 2006 | 12:53 PM
  #52
What gage is that "simple black ground wire"?
Old Jun 19, 2006 | 03:16 PM
  #53
I believe its a 12.
Old Jun 21, 2006 | 02:00 PM
  #54
took the fuel lines off today to take the manifold off and not a drop of fuel came out,,, I am really leaning toward a FPR now. can that cause the stumble?
Old Jun 21, 2006 | 03:08 PM
  #55
Fujimo's Avatar
Yes if the diaphram broke inside it, its just dumping fuel into the engine.
Old Jun 21, 2006 | 03:21 PM
  #56
93yellowta's Avatar
Damn I was looking for this post... hey sean1997ws6 ,update I put the new afpr on their still having the stumbling issue... just to let you know. I am getting dynotuned on the 1st. hopefully that will clear it up.. anyway when you pull off the vacumn line off the afpr can you smell fuel? I put on my new one and I can still smell it, I am thinking from running really rich at idle, come on new tune...
Old Jun 21, 2006 | 04:43 PM
  #57
playa7970's Avatar
my stumble happens off the line or when cruisin if the rpms drop between 1-2 rpms then i get a bad stumble also and it backfires pass 2k though....., and its all good weirdest thing oh yea and the car is fine at idle
Old Jun 21, 2006 | 04:44 PM
  #58
I believe its a 12.
Too small. The grounds return all the ungrounded power loads to the chassis. Look at the width and thickness of the ground straps.... way more conductor area than a 12-gage wire.
Old Jun 21, 2006 | 06:15 PM
  #59
is there anyplace i can get an original wire?
Old Jul 12, 2006 | 10:19 PM
  #60
problem fixed.. turned out to be the coil ground wire broke down. put a new one on and shes back.
