Bad plug wire?
Old Aug 30, 2009 | 04:05 PM
moparman's Avatar
Bad plug wire?
I've been noticing a miss from time to time. Finally scanned the car and #4 was showing a high misfire count. I could hear the snap of a misfire also. Pulled the old wire off, and sure enough, it was burned. Put a new wire on. Still occasional miss. Pulled the new wire off, not burned. Put it back on, hear the snapping sound. Scan tool says #4 is misfiring. Is it possible the new wire is bad?
Old Aug 30, 2009 | 05:06 PM
rclearyiii's Avatar
Snapped In?
It is easy to install a plug wire boot on the plug without getting the plug end correctly seated in the wire terminal in side the boot. Make sure that it firmly snaps into the terminal.
Old Aug 30, 2009 | 10:12 PM
greenmachinedriver's Avatar
probably loose wire but if its on tight check the porcilin (bad spelling) part of the plug for cracks or just go ahead and replace it
Old Aug 31, 2009 | 06:40 AM
moparman's Avatar
Well, the scan tool lied. Turns out it's not #4. When it got dark, I fired it up and could see wire #8 was the one that was arcing. It wasn't arcing before, so I guess I must have moved it when changing the #4 wire. Of course it may not have produced enough misfires for the tool to pick up, as I only ran it a couple of minutes.
Old Aug 31, 2009 | 09:29 PM
klrz28's Avatar
Lt1's love to eat plug wires
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Fatdog2
Feb 13, 2015 08:19 PM
