LT4 valve spring question, on a LT1
Old Aug 31, 2009 | 04:13 PM
it's allgood's Avatar
I'm doing a cam swap and looking to purchase the LT4 hotcam valve springs. Will i need the cups, retainers and locks or can i just swap the springs? I'm going to purchase the cam from SDPC. Any help would be great. Curt
Old Aug 31, 2009 | 05:34 PM
userchemical's Avatar
i would look at different cams and stay away from the lt4 hot cam. They make newer baby cams that make better power then the hotcam.
Good luck.
Old Aug 31, 2009 | 06:24 PM
I Would like to use a different cam but the price is right for the hot cam, idle is good and i dont have 400.00 for a tune right away. I know the LT4 springs are not that great but for now they will do. I like the GM 846 cam, cc305 on a 112,
Old Aug 31, 2009 | 06:32 PM
Stl94LT1's Avatar
Yes, you can just swap the springs.
Old Aug 31, 2009 | 06:43 PM
Umm...you are going to want to get a tune with the HOT cam, as well. The HOT cam kit is a good enough package for "ok for now".
Old Aug 31, 2009 | 08:02 PM
Bersaglieri's Avatar
The Hotcam is good. I wish I knew where these magical baby camshafts are located. The GM846 and CC305 are both good cams also. You dont need $400 for a tune, just a ALDL cable and a decent base cam tune [which you could probably find somewhere for free] or an ALDL cable and an email tune package, or send your PCM out to get reflashed. All less than $400. Also it doesnt sound like you need a custom cam either so if the price is right on the three above, go for it.
PS Fill out your signature area with year, other mods, etc.
Also I have an extra ALDL cable lying around here if you need one.
-Dustin-
Old Aug 31, 2009 | 09:40 PM
Dustin, yes I'm interested in the ALDL cable but I have OBD1. Will it work with that? And PM me the price of the cable. Thanks, Curt
p.s.s. lol I'll get my signature changed to correct place
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
