Bad PCM or Bad Injectors throwing off noid light??? ...opinions wanted ..NIGHTMARE!
Old Feb 28, 2019 | 08:47 PM
  #61
canbaufo's Avatar
Re: Bad PCM or Bad Injectors throwing off noid light??? ...opinions wanted ..NIGHTMAR
squarehead, thanks for the perspective on 2 strokes and taking time to read this....bottom line is I hope it survived it and hope to find out soon. Injuneer, truthfully as I think back on that oil change last May it was probably worse than described, probably 7+ quarts came out VERY quickly. As far as I know the engine wasn't run under load, but it may have been run long enough to get hot during the so called "troubleshooting". Enough to finally blow my header gasket that had a missing bolt for years but never blew before (it did blow right there though).
I actually found several AFPR's for the LT1 and finally settled on one recommended by a competent forum member here (I think it was Shoebox). I ordered it from Advanced (Borg Warner BWD-23065) for $65 grand total. I'll start by trying to get it adjusted right for "key-on" (would that also be 43.5 PSI since there's no vacuum compensation when not running?). Got the correct Schrader core #12570619 from Rock Auto as you pointed me to Fred, thank you. Should be a week or so before both arrive. The old stocker showed some corrosion on the inside and I wasn't going to give Aeromotive $200+ after all of this! I've read many RECENT posts of failures right out of the box! Often it causes multiple gasket or ring failures. Hoping my intake and head gaskets survived, they seemed to but I won't know until I can watch it run normally.
I wanted to get injector clips that work with SVO 42# green tops so I could see if the injectors leak with the key on while at this, but see conflicting info when reading posts regarding OEM clips working with the SVO's (no data on special clips existing). I have posted in an old thread here to see if anyone learned more about it. If the clip isn't tight or proper fitting enough to seal the upper O-ring it's pointless for me to use with the key-on test. I have an easy question (next) …..
During this troubleshooting I would like to disconnect the miserable inline fuel pump that is mounted and running dry (bypassed with a metal pipe), I don't want it shorting out and blowing a fuse or whatever might happen leaving it this way too long. I do not know which fuse it's on and assume it's tied into the same fuse the intank pump uses. Can I just heat shrink and/or electrical tape the heck out of the hot wire and fold it back on itself or something? Ground wire ok to leave hooked up? I did a search on it but kept getting home electronics pages talking about using wire ties to seal the ends of live wires.
For reference to help with the FP question in this post, what should the "key-on" pressure be with an OEM FPR? Seems like it would be 43.5 PSI just like when running with the vacuum line removed and plugged (since the vacuum line is taken out of the equation when not running). However, I realize the pump isn't running continuously during "key-on" and pressure is bleeding off ….so, 35-40 PSI? Looking for some frame of reference to use as a starting point with an AFPR (I think mine was set very close to stock 43.5 PSI). I decided go with an AFPR in case my "permanent" open loop tune needs to be compensated with small FP adjustments.
Many thanks!
Old Mar 7, 2019 | 10:45 AM
  #62
canbaufo's Avatar
I should be going across town to work on the car again within a few days. I had a few questions in the last post I'm curious about if anyone has time. Especially with regard to the inline fuel pump wiring. In summary I would like to disconnect the power to the bypassed inline fuel pump during troubleshooting, because it's sitting there running dry and not sounding good at all. Is it safe to disconnect the positive wire to the inline pump and zip tie a chunk of rubber over it (or use heat shrink)? I think it's on the same fuse or relay as the intank pump. I don't want to chase that and only want to temporarily disconnect the inline pump. If I get the car running properly again I'll simply replace the inline pump. Thanks for the reply on the injector clips in the other thread.
Old Mar 7, 2019 | 11:50 PM
  #63
When I installed my inline pump (part of an NOS dry nitrous kit, not current setup) I added a new relay for it back inside the hatch area. Ran 12 V from the battery (w/ 20A inline fuse), to the load side of the relay. Took 12 V for the signal side of the relay by splicing into the gray stock fuel pump wire at the harness connector at the plug over the rear axle. When the stock pump turned on it also turned on the inline pump.
See where the 12 V for your pump comes from, and disconnect it at point which has minimal exposure to the under the car environment. If you end up with a bare end on a live wire, cut the exposed copper off, bend the wire back on itself and wrap it tight with high quality plastic electrical tape. Go several inches past the end of the wire to minimize the chances of water entering. Use a plastic tie to hold the end of the wire up tight to the chassis, out of direct contact with road spray. A lot of people have done that with the connector for the skip shift relay on the T56 trans, incorporating a resistor, to defeat skip shift.
Old Mar 8, 2019 | 09:05 AM
  #64
canbaufo's Avatar
!CAGS was my very first free mod back in 1998 when I bought the car. I don't remember being that thorough, I think I just covered the connector really well and tied it back (no cutting). I won't be driving the car until I put a new pump on. Just to run it in the garage am I ok to just wrap up the end of the power wire really well with regular electrical tape and zip tie it back on itself, or will a copper end melt whatever I cover it with? I want to do it as you described but without cutting anything. I think the end of the power wire has a rubber boot if memory serves me well. Thanks for the advice.
Old Mar 8, 2019 | 08:00 PM
  #65
You can tape the bare end. Nothing gets “hot” unless there is current flowing, and there's no current flowing when the wire isn’t connected to anything.
Old Mar 9, 2019 | 10:40 AM
  #66
canbaufo's Avatar
Ok thanks, I thought that was probably the case but my understanding of 12v systems is limited. Well, I was planning on working with it today but have contracted the flu. Nothing like waiting longer!
Old Mar 15, 2019 | 07:06 PM
  #67
plattted's Avatar
You have a lot patience, Fred!
Old Mar 15, 2019 | 09:04 PM
  #68
canbaufo's Avatar
Talking Resolved !!!
I reinstalled the rail assembly and installed a new fuel filter yesterday before starting the engine and made the following observations:
- Key on to prime the system didn't register any FP for a few tries but I reminded myself of the lost fuel during rail and filter R&R, so I kept trying
- After about five primes the FP hit 42 PSI (I left the new Borg Warner AFPR set as it was out of the box)
- Key off and the pressure would bleed down to 38 - 39 right away but then very slowly bleed down to about 30 PSI (around 20 minutes). I could not detect any fuel leaks in the engine bay or under the car, so I decided it was finally "time".
- Started the car and it fired up beautifully, making about 37 PSI. I disconnected and plugged the vacuum source for the AFPR and observed a steady 45 PSI, engine only slightly less happy idling at that pressure (normal observation) but still a good idle.
Since it ran so well I didn't tamper with the AFPR adjustment and will only do so if necessary once I begin driving the car under load again. The throttle response is crisp as ever. There was smoke from the exhaust at first but I believe it was only residual crap burning off, old fuel / water in the exhaust, carbon, etc. It was dark outside and when I shined the flashlight on the smoke it didn't appear blue. I shut it off for a few minutes while observing the engine bay again for fuel leaks. Then re-started it and no more smoke from the exhaust. I changed the oil to conventional 10W-30 yesterday just before all of this; the old oil had some gas in it, but nowhere near what I discovered last May when I changed the oil after the hack mechanic had run the car so much during "troubleshooting".
My gut tells me everything is ok, but time (and maybe more Blackstone analysis) will tell. There was a bit of nickel colored sludge on my magnetic drain plug and it was also evident in the Pure One oil filter). I have seen this with all oil changes but I think there was a bit more than usual this time. The time before, when I changed the oil the hack mechanic polluted, it came out so fast it washed the magnetic drain plug off (so much fuel in oil it was watery). Maybe the engine survived due to not being run under load with these conditions. I will change the oil again soon just to continue to flush out and dilute any remaining fuel.
I want to give everyone who's followed along and posted here a BIG THANK YOU !!!!, especially … "Injuneer (Fred)"! I had really lost most hope after all of the things that had been tried and the difficulty of driving across town to work on it in a small space. Even after discovering the bad Aeromotive AFPR I still had doubts that it was the only problem I was facing, especially since the ex mechanic had shown me the noid light issues in person. Perhaps a horribly rough running engine is enough to throw a noid light off a bit, or maybe his was on the way out. I've recently read that noid lights don't always tell the truth, unless it's just not lighting up at all from one driver but lighting up powerfully on another.
It really makes me sick that my car has seen 1.5 years of down time due to a problem that could have literally been diagnosed in a few minutes. I may have to find a way to take this up with Absolute Horsepower LLC, as I have lost a lot of time and some money (and endured great duress) due to their numerous errors and the "run around" waiting game they put me through as well. Not to mention they literally destroyed some parts (like the inline fuel pump with power left on it while bypassed of the fuel line). There's far more I could tell about how badly it all went but there's no point in it here.
It is also entirely appropriate to add that here we have yet ANOTHER utter condemnation of the infamous Aeromotive AFPR !!!!!!!!!!
Fred, thank you again so very much for all of your feedback and the very helpful highly-detailed information. It gave me the confidence to keep going!
Old Mar 18, 2019 | 11:46 PM
  #69
squarehead's Avatar
Canbaufo,
I am happy for you. I hope the car runs well under load and puts a smile on your face again!
Old Mar 19, 2019 | 12:53 AM
  #70
canbaufo's Avatar
Post Re: Bad PCM or Bad Injectors throwing off noid light??? ...opinions wanted ..NIGHTMAR
Originally Posted by squarehead
Canbaufo,
Thanks. I'm just a shade tree "mechanic" at best and was getting ready to sell this car anyway (1.5 years back ). Was quite a nightmare dealing with the unscrupulous former mechanic (now a former friend too) and feeling like I needed to learn everything I could about a car I had mostly lost interest in (I'm into motorcycles now). Nothing like paying insurance, registration and taxes on a car that's sitting with an unresolved issue across town in storage (at least it's all pretty cheap). I really do look forward to seeing it in it's former glory again though, it's the only way I feel right about letting it go. Plenty of work to do yet ...but it feels like it will possibly or probably be worthwhile now.
I've read a few horror stories about people breaking header bolts off in their heads and having to pull the head or drop the engine to repair it (lol so now that's my worry about the next significant thing I need to do). There was a slight leak in the driver side header right in the middle (at least it's easy to access) due to a missing bolt. Hoping I can get a good stainless 1" 3/8-16 in. bolt from Fastenal and just pop it in to seal the leak (gasket doesn't "appear" blown and you can't hear it, couldn't even see it last time it ran). It may have been leaking due to the intense flooding when the Aeromotive POS AFPR was "passing gas". Anyway, I suspect in the end I'll have to replace the header gasket. I have an unused Felpro 1406. If I use it I'll get the ARP 400-1210 bolt kit. Haven't done a header gasket before. Doesn't look or seem bad but then I read the horror stories of broken bolts (upon removal and installation). Arrrghh lol.
Mswezey
Sep 15, 2011 05:05 PM
dStruct
Sep 23, 2010 08:05 AM
tattoofever
May 12, 2007 11:31 AM
3800FBL
Oct 24, 2006 01:52 PM
Spinner
Mar 15, 2005 11:04 PM
