Bad Opti.... Cap & Rotor or Optical Sensor Backside?
Old Sep 13, 2006 | 08:53 PM
Mike96z's Avatar
I have a bad opti that got wet I guess, which part of the opti do you think went bad? The cap and rotor or the backside which has the optical sensor? I just wanted to know because I have a cap/rotor laying around I want to put on to see if it will fix it, if you guys says its the optical side I'll just wait. Opinions?
Old Sep 13, 2006 | 08:55 PM
Mike96z's Avatar
Re: Bad Opti.... Cap & Rotor or Optical Sensor Backside?
It did get wet.
Old Sep 14, 2006 | 06:58 AM
3DFORMULA's Avatar
If you have power out of the coil, then it is the cap and rotor that is the problem.
My old '94 Z got wet a few times and died, but then restarted after a while.
Old Sep 14, 2006 | 12:40 PM
If there is damage to the optical sensor, you will get codes for it. (P0372 for high res pulse, P1371 for the low res). No codes for the high voltage section.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carcrazyQT
Sep 3, 2002 02:51 PM
