bad opti?
Old May 18, 2007 | 06:26 PM
  #16
Camaro1996's Avatar
Originally Posted by fbodyboy
injectors are a good probablity. on my first transam i had, it had a hesitation and stumble at idle. first thought it might be opti but decided to try an injector flush because it needed one do to mileage. cleared the problem right up and even increased milage a noticable amount.
What about just getting new injectors? It may be expensive, but how effective is injector cleaner?
Old May 18, 2007 | 10:34 PM
  #17
mrseven's Avatar
You can check the resistance on each injector for starters. Should be about 14 ohms if I remember correctly (Haynes manual is a must! )
Also, check for a burnt spark plug wire. I had one that resembled a bad opti, and it took me forever to figure it out.
FYI for the coil question, on older cars the tach actually pulls the RPM signal from the low tension side of the coil. So a bad coil can actually throw off your tach.
Good luck with that stumble! I feel your pain
HectorM52
Jul 30, 2017 11:46 AM
beltrunner
May 17, 2015 10:18 PM
BLK1997Z28
May 7, 2015 03:01 PM
Noenav
Apr 30, 2015 01:06 PM
ad356
Apr 11, 2015 10:30 PM
