Bad MAF?
Old Aug 16, 2009 | 11:59 PM
henryz28's Avatar
Bad MAF?
What will a bad maf do to the car when it is damaged or went out. My car will sometimes die when I try to start it. Once I get the car to run it will idle ok but it has a slight miss, and it also has a slight miss at part throttle. At wot there is no miss. But it idles rough and has a gas smell at start up. I started the car today and unplugged the maf; the car's idle went up, and it continued to idle about the same just a little higher rpm with the same slight shake. I have no codes on; Will a bad maf always throw a code? Also, I did clean the maf with this once http://www.q45.org/maf/cleanmaf%20008.jpg
Old Aug 17, 2009 | 08:30 AM
Unplugging stuff is a poor way to diagnose. Do a real time scan to see what is going on.
Old Aug 17, 2009 | 12:07 PM
dangalla's Avatar
could be a bad coolant temp sensor. bad spark plug wires or opti also
you really need to scan it to see what is going on
Old Aug 17, 2009 | 03:33 PM
henryz28's Avatar
I changed out the opti and the cap and rotor with a msd cap. Then I checked out my plug wires and found one bad wire; I changed that wire and replaced all the plugs. Now I am going to breakdown and buy a scan tool. Will this one work?http://www.obdcom.com/?gclid=CPPAuZv-qpwCFRBbagodMmE0jA
Old Aug 17, 2009 | 07:25 PM
Make sure it includes "GM Enhanced Parameters".... it will be much more useful if it does. Not all OBD-II software includes that.
AutoTap has the GM Enhanced Parameters, but it costs a lot more.
Old Aug 17, 2009 | 09:03 PM
henryz28's Avatar
I am going with auto tap. What is the difference between with and without the the GM Enhanced Parameters? Is this all I need? http://cgi.ebay.com/ebaymotors/Autot...4506.m20.l1116
Old Aug 18, 2009 | 12:52 PM
henryz28's Avatar
Can I get away with buying the Auto tap Software upgrade for GM enhanced parameters for the ATU or ATS for $99 then apply that to different hardware like a ElmScan 5 OBD2 Scan Tool Kit for $99. Or do I need the auto tap kit for $199 and the Auto tap Software upgrade for GM enhanced parameters for the ATU or ATS for $99. Thanks
Peytons'z
May 6, 2021 09:25 AM
SpeedJunkee
May 3, 2015 08:49 AM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
