Bad MAF
Bad MAF
I have been fighting a high RPM misfire/detonation for a while now and think I have found the problem. I unplugged the MAF, and it doesnt misfire in speed densidty mode. So does this just mean the MAF is bad, or that maybe something else is wrong? Should I buy an after market MAF or a Stocker?
I first encountered the problem when I installed my Delteq after my Opti went out.
Ill probably borrow a buddys MAF to test and see if that is the problem.
Only motor mods are: U/D Pulleys, Delteq, CAI
Thanks for the help.
Re: Bad MAF
Is it possible you have some of the Delteq high voltage wiring running in parallel with the MAF sensor wiring?
Have you checked for codes?
Add a "signature" with basic info about the car.... like year.
Re: Bad MAF
I have the cable and the pcmcomm software. I dont have the full version so I cant record anything. But I Was getting knock counts in the 4k+ and it was retarding my knock as much as 7-11deg. My spark advance was also 40deg while driving around town but would drop to 20deg at WOT.
What program could i use thats free to read my codes?
Re: Bad MAF
carguyshu
Jan 22, 2017 11:19 AM
formula218
Dec 2, 2014 04:27 PM
