bad icm ground
Old Jun 9, 2012 | 12:14 PM
ant170's Avatar
bad icm ground
1995 lt1 no spark ,I have a bad icm ground I've cleaned and checked every ground wire. The opt is new and had icm checked . The car ran fine sat 4 a week and no start.
Old Jun 9, 2012 | 01:20 PM
Kevin Blown 95 TA's Avatar
Re: bad icm ground
If you're sure it's the ICM ground, then run a wire from the battery over there and see if it starts working. You hear the fuel pump prime? You checked it for spark at one of the plugs or the coil?
Old Jun 9, 2012 | 01:40 PM
Re: bad icm ground
How did you determine you have no ground to the ICM?
Have you scanned it for codes?
Old Jun 9, 2012 | 01:48 PM
ant170's Avatar
Re: bad icm ground
No codes. I used a ohms meter as shoebox site states. I'm getting a reading of .57 every thing else is good.
Old Jun 9, 2012 | 03:16 PM
Re: bad icm ground
.57 ohms? Are you sure about the scale and did you check your leads to make sure when touched together you got 0 ohms?. .57 ohms is a ground, it's just not 0. That could even be from a marginal connection to your meter leads. I'd be a little skeptical this is really your trouble. What did you get during cranking on the white wire (B) using the ac scale?
Old Jun 9, 2012 | 05:09 PM
ant170's Avatar
Re: bad icm ground
Yes I got 0 ohms when I touched them together. The white wire has 2.40 ac volts
Critter
Jul 7, 2015 08:33 PM
zxtce
May 7, 2015 08:53 PM
ad356
Apr 11, 2015 11:12 PM
eanhl2004
Apr 4, 2015 12:01 PM
USAirman93
Nov 24, 2014 03:37 PM
