bad dyno results????
Old Oct 9, 2005 | 10:12 PM
nightrider93's Avatar
i went and dynod here at rpm in lewisville i put down 243.6hp 291.4 lbs torque to the wheels is this bad i got hooker long tubes, y-pipe 2-1, slp intake, ovc wires and airfoil. i also have an a4 1993 with 128,800 miles never been tuned or touched. please post back with any info i though i would have a little more but the guy said being an auto i lost some too. what else can i do that i will notice the biggest power gains from. thanks thomas
Old Oct 9, 2005 | 10:18 PM
Jameslt1TA's Avatar
Re: bad dyno results????
If you post a dyno graph we can look at it to see if you've got an ignition miss or something. You can also do a compression test, and test the fuel preasure.
Old Oct 9, 2005 | 10:19 PM
Jameslt1TA's Avatar
Oh ya and dont forget to check the small things like plugs and wires make sure they are all in the right order and on tight. How old are the plugs?
Old Oct 9, 2005 | 10:30 PM
vin1382's Avatar
was it a mustang dyno?
Old Oct 9, 2005 | 11:07 PM
no all they do is ls1, lt1 ls6 cars the plugs and wires are all less than 5 thousand miles i will post the graph tomm. thomas
Old Oct 9, 2005 | 11:23 PM
homey's Avatar
A mustang dyno is a current eddy dyno, some say the numbers are low compared to a dynojet but in reality they are more accurate not low. just a differernet type of dyno,
Old Oct 10, 2005 | 12:11 AM
Alvin@pcmforless.com's Avatar
Get that graph up here and we can really help find out whats going on.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
TitoPR221
May 26, 2015 12:20 AM
BLK1997Z28
May 7, 2015 03:01 PM
Russ95Z28
Apr 23, 2015 01:55 PM
ad356
Apr 11, 2015 10:30 PM
