bad bog
Old Apr 7, 2004 | 06:52 PM
ponykillr75's Avatar
bad bog
i dont know what this is but in all gears at different rpms and not consistently it bogs like hell i changed the knock module but with both im getting up to 15 degrees knock retard what else would cause this
oh yea its only under 3/4 to full throttle
if i can figure out dataqmaster i will post a log
Old Apr 7, 2004 | 08:04 PM
slopokrodrigez's Avatar
First try disconnecting the knock sensor and see if the bogging problem goes away. Then test the sensor to see if it's functioning properly.
Old Apr 7, 2004 | 08:09 PM
so just drive with no knock module at all???
Old Apr 7, 2004 | 08:37 PM
Yes with it disconnected.
Old Apr 7, 2004 | 08:46 PM
so where are the sensors i need to diconnect
Old Apr 8, 2004 | 04:52 AM
Thank Rob(shoebox) for the pics.
Look here
http://shbox.com/1/ks.jpg
What scanner are you using that told you there is 15deg of knock retard?
Old Apr 8, 2004 | 04:55 AM
Bersaglieri's Avatar
Would a LT4 KM solve that also? I am having the same thing.
-Dustin-
Old Apr 8, 2004 | 05:11 AM
Don't believe it will fix the problem. Suggest you locate the source of the problem. Changing components to "mask" the problem will only give you temporary relief. The long term implications could be bad.
Since the sensor is built around a piezo crystal, defects can occur in both directions. That is they can become less sensitive (if you want to look at it that way) and more sensitive.
Don't forget there are other sources of knock as well. Bad bearings in components, loose items such as shields or loose connections such as engine mounts.
One thing you can do is put KOEO and check the knock signal. Then wrap on the engine with the back of a screw driver and check the knock signal. Now start the engine and watch the knock signal. Then try listening for the source of the knock with screwdriver stethoscope as I call it. You could also remove some accessories by say for example removing the belt that drives the accessory.
One other item of interest. If the rectifier in the alternator is going bad and leaking AC on the DC supply cable. It can DRASTICALLY effect the PCM. If there is as little as 0.03 VAC on the DC supply cable, the PCM can and will go nuts. To measure if that could be the problem, put your DVM on AC Volts lowest scale. Measure from a clean ground to the charging post on the alternator. Be sure the AC component is not over .03VAC.
zajones
Jul 30, 2015 02:18 PM
vwb11356
Jul 22, 2015 06:51 PM
Bz8
Jul 13, 2015 04:46 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
