Backfire with loss of power
Old Jan 18, 2009 | 07:59 PM
  #16
Skullified's Avatar
yeah heads sorry and it isn't straight pipes sorry my first fast car still learning and how do i check the exhaust valves then. Full dual Borla exhaust with the y pipe. It misfires when i shift crappy (still getting the hang of the 6 speed)
Old Jan 19, 2009 | 07:35 AM
  #17
Skullified's Avatar
its running real rich before i bought it it was sitting for a while and now i get out of the car and smell gasoline pretty bad which i expect fumes from a 5.7 L but still thats pretty bad
Old Jan 19, 2009 | 10:52 PM
  #18
The fact that its a 5.7L engine does not mean you should smell "fumes". A well tuned, carefully maintained 5.7L (or any other displacement) LT1, with cat(s) should burn clean and have a neutral exhaust smell. Take off the cat and any car will stink. Have a problem with misfires and/or exhaust leaks, or an exhaust valve that isn't closing fully, and the computer is going to cause it to run pig rich and stink even more. Have you ever checked the lash on the valves?
If it has a Y-pipe, it isn't "full-dual" exhuast. A full dual exhaust would have headers, with a pipe off each of the header collectors, directly to the back of the car on each side (bank), and a muffler (or maybe not a muffler) on each side. Once you use a Y-pipe, you no longer have a dual exhaust.
Old Jan 20, 2009 | 06:02 AM
  #19
Skullified's Avatar
Yeah I am going to put cats on it and make it a true dual exhaust that's what i wanted to do when i got it but my funds are going to be a little low after i get new tires and paint it and I'm going to check for an open valve tomorrow thank you!
Old Jan 20, 2009 | 09:03 AM
  #20
hairbear21's Avatar
Paint [I]before[I] making sure that it runs correctly?
I can understand having a nice looking car, but if it runs like a dog, isn't it pointless to paint it?
Old Jan 20, 2009 | 10:42 AM
  #21
Skullified's Avatar
well yeah it runs great now like injuneer said i just needed to drive it for a while hasn't backfired since, the tires are next and then the minor problems with the car needs a new drive side window motor, need to hook the speakers, get the heat working which i think its just the thermostat. Then comes the body work and paint
Old Jan 20, 2009 | 10:44 AM
  #22
Skullified's Avatar
its cold and snowy here anyway, not going to paint it untill its gets warmer out
Old Jan 23, 2009 | 07:48 AM
  #23
Skullified's Avatar
Ok so i know the gas mileage won't be good but i got about 100 miles on a full tank!! thats awful does it need a tune up? How much would putting mufflers help?
Old Feb 3, 2009 | 07:45 PM
  #24
Skullified's Avatar
ok so replacing worked for the most part but when i try to accelerate kind of hard it will backfire it sounds like it is coming out of the right exhaust would this have anything to do with the fact that my left side of the exhaust has a muffler but not the right? Could this backfire have anything to do with my headers?
Old Feb 4, 2009 | 12:11 AM
  #25
mr.green's Avatar
Putting mufflers on when it already has one would be kind of pointless. It wouldt backfire due to one exhaust pipe going through the muffler. Are you sure its not when you let off the gas and it "cackles" from hard accelaration. You can check for an exhaust leak around the headers.
Old Feb 8, 2009 | 06:57 PM
  #26
Skullified's Avatar
its not on the decel even tho that has happened its when i accelerate kinda hard. Ill check the exhaust around the headers.
Old Mar 2, 2009 | 01:32 PM
  #27
Kossism's Avatar
did you ever find out what was wrong here? i am interested because i have a 94 z28 with stock exhaust cool air intake and larger throttle body that seems to have close the same problem. i seem to be having a bad misfire at low rpms and high rpms but only at full throttle and only under a heavy load it wont misfire when i am not in gear no matter the rpm. i am also seeming to get a tick from the left side of the motor. ive been told that the tick can be an exhaust leak or a lifter not really sure.
also in oct. last year i replaced the water pump opti and fuel pump and radiator plugs and wires about a year before that. i havent replace the coil which was my first thought but not really sure.
Old Mar 4, 2009 | 11:31 PM
  #28
Skullified's Avatar
I have yet to fix it im thinking that it could be an exhaust leak but i doubt it i think the timing is off on my car or my plugs are getting wet because it is running too rich. My car in low RPM's runs like a v-6 its like the plugs get wet and the spark has to dry out the plug which doesn't happen untill 2800 RPM's our so ill keep you updated i should be getting somewhere tomorrow
Old Mar 4, 2009 | 11:32 PM
  #29
Skullified's Avatar
check and make sure your wires are cracked or burnt thats what made mine run terrible at first but i replaced those and it ran good still backfired though
Old Mar 4, 2009 | 11:34 PM
  #30
Skullified's Avatar
i also replaced the fuel filter and that helped a great deal when was the last time you replaced that?
