b&m trick shift
Old Mar 10, 2003 | 11:53 AM
phancom's Avatar
b&m trick shift
anyone ever use this? im thinking about changing to it when i install my shift kit.
Old Mar 10, 2003 | 12:50 PM
phancom's Avatar
TTT
Old Mar 11, 2003 | 04:22 AM
Pro Built Automatics's Avatar
B&M Trick Shift is Ford type "F" reworked to their specs. It is designed to be used with asbestos type clutches, problem is there hasn't been asbestos in clutches since 1977. According to Borg Warner, Raybestos, Alto, and Trans-Go, this fluid has less holding power on "dynamic" type clutches, and can shorten the life of the transmission. Use a good quality Dexron III, and if you want firmer shifts at WOT, then use a Trans-Go Performance Shift kit, along with related upgrades. Last, don't use the fluid to try to change shift characteristics.
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
marlar98
Sep 19, 2015 07:53 AM
