which autometer guages..water temp/oil temp-mech or elec
Old Sep 5, 2006 | 08:37 PM
TransAm396's Avatar
Ok ..im about to get my last two guages...2 5/8 water temp and oil temp to go into my car. Now for the water temp..do I need electronic or mechanical? and for the oil temp..which is the one that comes with the probe? the electronic or mechanical?
Old Sep 5, 2006 | 10:01 PM
TransAm396's Avatar
Re: which autometer guages..water temp/oil temp-mech or elec
Old Sep 5, 2006 | 10:25 PM
razor02097's Avatar
Take your pick. Electric is easier to put in.
Old Sep 5, 2006 | 10:26 PM
SnakeOiler's Avatar
Electrical would be easier, definitely.
Old Sep 5, 2006 | 10:31 PM
Both a mechanical gauge and an electronic gauge will come with a "probe'".... in the case of the mechanical, its a 6-ft capillary tube with a bulb on the end. The tube has to be routed through the fire wall, and the bulb inserted in a convenient opening. With the electronic, the probe is a thermistor that screws into a convenient opening, and connects via a wire to the gauge.... definitely a lot easier to deal with than running the capillary tube.
I have an electronic oil temp sensor screwed into the oil drain plug.
Old Sep 6, 2006 | 05:56 AM
97WS6SCharged's Avatar
Get the electric version. As stated, they are easier to install. You also don't have to worry about oil leaks inside the car.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Bobczar
Oct 23, 2015 11:22 AM
68SuperRam
Classic Engine Tech
Dec 9, 2002 01:13 AM
