Automatic trans issues please help
Old May 19, 2010 | 04:37 PM
elis94camaro's Avatar
I have a 1994 lt1 camaro with an automatic trans.While I was driving today it wouldnt shift into second so I let go of the gas and then pressed it again and it shifted . Is this a mechanical issue or an electronic issue.Now I just parked it so I wouldnt mess anything up.Could it be a bad tps?Please help me with anything you might know or have had a similar experience.THANKS for reading
Old May 19, 2010 | 07:30 PM
byrons1502's Avatar
1does it do it all the time or just once
2is all the other gears there.
3 was u wot or cruising.
Could be mechanical or electronic. scan for codes if it does it all the time.
Old May 19, 2010 | 09:20 PM
1.It barely started doing it today, i am going to drive it tomorrow to see if it still does
2.It shifted into 2nd dont know if it got into 3rd, i do know it got to 35 mph though
3.I was cruising
Old May 19, 2010 | 09:48 PM
byrons1502's Avatar
check the fluid with the car running and scan for codes. If it does not act up tommorrow hope it was a fluke.
PCLZ28
Dec 24, 2015 05:19 PM
Brake_L8
Jan 20, 2015 09:44 AM
capebuf
Jan 13, 2015 07:22 PM
Jan 5, 2015 07:14 PM
Sarahrope64
Nov 27, 2014 11:17 AM
