Auto Trans Fluid in an M6
Old Apr 24, 2003 | 10:55 AM
scoobysnax83's Avatar
I've heard this a couple of times, is this true. And if so what kind should I put in? Thanks
Old Apr 24, 2003 | 11:33 AM
slashz28's Avatar
yup, its true something equivalent to dexron 3 should be used. i used mobil 1 synthetic atf, no probs. from what ive seen on here, lots of people use different brands, which is best really, i dont know. hth
Old Apr 24, 2003 | 11:46 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I have heard mobile 1 synthetic is good but i jsut used good old Honda ATF. Get it at autozone cheap and a lot of guys have used it.
Chris
Old Apr 24, 2003 | 01:54 PM
curiousity?!?!
Whats the reason for not using manaul tranny fluid?
Old Apr 27, 2003 | 03:16 AM
I dont know, i guess the ATF just works better........................
Chris
Old Apr 27, 2003 | 04:27 AM
Twice The Fun's Avatar
i also have heard honda ATF works great.
Old Apr 27, 2003 | 04:54 AM
Well, I changed it over to Dexron III yesterday, but I noticed on the bottom of my tranny theres a sticker there that says use Dexron II or equivalent? Whats up with that?
Old Apr 27, 2003 | 07:49 AM
onebadponcho's Avatar
You're fine using Dextron III because it exceeds the specs for Dextron II; plus I don't even know if they make the Dextron II anymore.
Also, the whole fact that there's a sticker on the tranny saying to use the ATF is plenty good enough reason for me. Those T56s are freakin' expensive!
Old Apr 27, 2003 | 09:10 AM
Mike94ZLT1's Avatar
The reason that you use ATF fluid in most newer transmissions is the parts are machined so precise, and the tolerances are so close that you need a lower viscocity lubricant (ATF) to be able to work its way in properly. Most manual fluid is something like 80w90, and is close to the consistency of maple syrup. I have had several of these cars now, and every one I have had I have put Honda ATF Z-1 in. Shifts like butter.
PCLZ28
Dec 24, 2015 05:19 PM
Moshbmx1
Feb 17, 2015 10:51 AM
jb4xx
Feb 2, 2015 10:00 PM
rockync7
Jan 1, 2015 05:10 AM
Sarahrope64
Nov 27, 2014 11:17 AM
