Auto meter A/F gauge ?
Old Jul 11, 2003 | 11:44 AM
chevy1963's Avatar
Ok just got thew meter hooked up and is it suposed to jump around alot ? It'll flash to Stoich and then back down to lean.
Then if I'm at WOT it goes to rich and stays there, but during normal driving it jumpes around.
Is this right.
Old Jul 11, 2003 | 12:26 PM
john97z28's Avatar
Yes it is. It is accurate at WOT. There is info on auto meter's site, here's a link: Auto Meter Go into the Tech Tips/FAQ section and click on Air/Fuel Ratio tab.
I thought the same thing when I first installed mine.
Old Jul 11, 2003 | 01:28 PM
jus_creepn_z28's Avatar
Question WOT
I've been seeing the term WOT on here a lot and I'm curious to what it means. I"m kind of new here so I don't have all the "slang" down yet. Thanks
Old Jul 11, 2003 | 01:30 PM
john97z28's Avatar
Re: WOT
Wide Open Throttle
Don't feel bad, there is still a lot of slang that I don't know.
Old Jan 3, 2004 | 03:38 PM
Charlie Streetman's Avatar
Resurrecting this thread.
So if under WOT, it is 2 bars in the green, does it need to be leaned out a bit. If so is something that pcm4less can do since I have that already.
Thanks,
Charlie
Old Jan 3, 2004 | 06:22 PM
Canadian z28's Avatar
My guage does the same thing. stays rich on WOT and dances around the rest of the time
Old Jan 4, 2004 | 05:25 PM
arnie's Avatar
It's a toy! Basically useless, unless you consider a gauge telling you, ya it's rich, or, ya it's lean. If you are interested in tuning your vehicle, you want, no, make that insist you know what the A/F ratio actually is. Usually, one gets what he/she pays for. In this case, you're getting ripped. However, if you like needles or meters to have movement, then this one is for you. Fasinating meter, isn't it?
BTW, if you follow this forum any, you should know that the oem pcm, factory programed, will be rich at WOT. What else is new?
Magenta_Hearts
Mar 30, 2015 09:42 PM
Moshbmx1
Feb 17, 2015 10:51 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
phantasm99
Aug 28, 2002 11:01 PM
