Auto meter A/F gauge ?
Ok just got thew meter hooked up and is it suposed to jump around alot ? It'll flash to Stoich and then back down to lean.
Then if I'm at WOT it goes to rich and stays there, but during normal driving it jumpes around.
Is this right.
Is this right.
Yes it is. It is accurate at WOT. There is info on auto meter's site, here's a link: Auto Meter Go into the Tech Tips/FAQ section and click on Air/Fuel Ratio tab.
I thought the same thing when I first installed mine.
Re: WOT
Originally posted by jus_creepn_z28
I've been seeing the term WOT on here a lot and I'm curious to what it means. I"m kind of new here so I don't have all the "slang" down yet. Thanks
Don't feel bad, there is still a lot of slang that I don't know.
BTW, if you follow this forum any, you should know that the oem pcm, factory programed, will be rich at WOT. What else is new?
carguyshu
Jan 22, 2017 11:19 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
phantasm99
Aug 28, 2002 11:01 PM
