ATTN: Shoebox
Old Mar 27, 2007 | 01:51 PM
ZL1modified's Avatar
ATTN: Shoebox
i need a couple part #'s or info?
first is the little rubber boot that goes on the vent tube that runs from the bottom of the opti-cap to the intake...(cap side of vent tube)
second is the part that holds the battery down...(it is a little black piece that has a hole in for a bolt and a lip on it that clamps down on the battery.)
thanks,
mike
Old Mar 27, 2007 | 03:57 PM
If you want something specifically from me, you should email me-not use the board for personal messages. I'm sure others would appreciate it.
AFAIK, the boot you speak of is not available separate from the opti vacuum harness.
GM PART # 14005061 is the battery hold down retainer.
Old Mar 27, 2007 | 04:02 PM
i thought that this could be info someone else may need in the future...
thanks, i'll keep that in mind next time...
and thank you for the help...
KYWes
Jun 14, 2022 06:52 AM
gelbza
Jul 12, 2015 08:10 AM
mrz28M6
May 16, 2003 04:24 PM
rmackintosh
Mar 18, 2003 05:20 PM
Coop1
Feb 27, 2003 08:10 PM
