ATI Super Dampner belt question
Re: ATI Super Dampner belt question
I installed my ATI damper this weekend... it is a 6.75" I ended up with a 63 inch belt... seems like it is a tad loose but it isn't squeeling so I am using it for now.. i would say 62" would be better if you can find one
Digging up an old thread but they make a 62.5" Gatorback belt: part #4060625.
Since the stock damper OD is 7.5" and the ATI 917271 is 6.75", if you do the math and assume the belt runs over about 260 degrees of the damper, then the change in belt length is 1.7" which gives a belt length of 62.5". If it's over 225 degress, that gives a belt length of 62.7".
stockssn2o
May 25, 2015 08:54 AM
1LEThumper
Jul 14, 2003 12:45 PM
