ATI Super Dampner belt question
Old Mar 4, 2006 | 10:18 AM
Honda Hunter's Avatar
When using the part# ATI-917271 ATI Super Dampner what size belt do you use? Thanks
Ray
Old Mar 6, 2006 | 08:54 PM
white97T/A's Avatar
Re: ATI Super Dampner belt question
I installed my ATI damper this weekend... it is a 6.75" I ended up with a 63 inch belt... seems like it is a tad loose but it isn't squeeling so I am using it for now.. i would say 62" would be better if you can find one
Old Apr 22, 2006 | 10:18 AM
Jeff95TA's Avatar
Digging up an old thread but they make a 62.5" Gatorback belt: part #4060625.
Since the stock damper OD is 7.5" and the ATI 917271 is 6.75", if you do the math and assume the belt runs over about 260 degrees of the damper, then the change in belt length is 1.7" which gives a belt length of 62.5". If it's over 225 degress, that gives a belt length of 62.7".
Old Sep 12, 2006 | 03:58 PM
Josh'95Z28conv's Avatar
TTT because this just saved me a lot of work
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
1LEThumper
Jul 14, 2003 12:45 PM
