ati balancer & bolt comming loose.
Old Jun 5, 2007 | 02:49 PM
hotheadbuddy's Avatar
Question ati balancer & bolt comming loose.
ok fellas im finished with the stroker i just finished a month ago and thanks to all of the replys to questions i posted its finished. now my problem is my ati balancer and arp bolt are comming loose i noticed it when my new belt started wearing. i removed the bolt , pressed the balancer back flush with the crank, took a baby tooth brush with brake clean and cleaned the threads in the crank in case there was any residue.there was not. i cleaned the arp bolt added red locktite and torqued bolt to 75 ftlbs. again bolt is loose when i rechecked after 150 miles . ati balancer is 0 balanced callies dragonslayer 3.875 crank 0 balanced and spec stags 3+ 0 balanced. i assembled everything correct but i did not do any machining . performance shop balanced crank ati balancer should be 0 balanced and spec clutch said they for sure 0 balanced clutch assembly. can not find problem. has any one had this problem? or can help on this one thanks.
Old Jun 5, 2007 | 07:33 PM
Lonnie Pavtis's Avatar
What type of key do you have in the balancer? Are you sure it is installed? This will cause your problems.
Old Jun 5, 2007 | 08:28 PM
JAKEJR's Avatar
Good Point.
My EAGLE stroker crank has two keyways, one for the timing chain gear key and a second one for the damper.
When I inquired with ATI I was told that some aftermarket cranks have a snout diameter that is too small and that won't allow a tight fit of their damper. I'm going with their 917274 for the engine I'm building; it's specifically for a Vette.
Jake
Old Jun 5, 2007 | 09:04 PM
wicked_95z's Avatar
I have had this happen a few times. It even came off the snout once while driving, which is why I have new tubular a-arms. I was told by a local shop that it could be caused by improper balancing.
Old Jun 6, 2007 | 05:29 PM
1fastlt1's Avatar
Exclamation
Man check that thing out really good! I went through the same thing with an aftermarket balancer on the stock crank! What was happening is the balancer was spinning on the crank and losening the bolt! Long story short it screwed up the crank now I'm finally getting around to rebuiling it after not driving it for a year and a half!
Old Jun 6, 2007 | 09:58 PM
Dave89IROC's Avatar
are you running two whole(not regular LT1) keys?
Old Jun 7, 2007 | 10:28 AM
1racerdude's Avatar
Ya need to check the size of the crank snout.
If it is small and the balancer moves it will loosen the bolt. Get a good star lock and see if that will hold it--
Old Jun 7, 2007 | 11:48 AM
blown383's Avatar
You might also check the length of the ARP bolt because I remember reading a few forum members had issues with the ARP crank snout bolt being slightly too long.
-B
MadMav
Feb 6, 2015 11:02 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
ddr698
Jan 9, 2015 10:05 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
1LEThumper
Jul 14, 2003 12:45 PM
