View Poll Results: Assembly lube or heavyweight oil?
Assembly lube
17
89.47%
Heavyweight oil
10.53%
Voters: 19. You may not vote on this poll
Old Aug 10, 2006 | 06:44 AM
buddy95z's Avatar
Just curious what everyone is doing when camming there stock bottom ends. Are you using assembly lube or just coating everything in heavyweight oil?
Thanks for all input. Have a nice day.
Old Aug 10, 2006 | 09:26 AM
WS Sick's Avatar
Re: Assembly lube or heavyweight oil?
Assembly lube, the heavy oil will run off on a hot day leaving you with mildly oiled bearings for the first start-up.
Old Aug 10, 2006 | 10:05 AM
SSCamaro's Avatar
what about a pure moly based *** lube?
Old Aug 10, 2006 | 10:54 AM
rskrause's Avatar
Moderator
*** lube and lots of it!
Rich
Old Aug 10, 2006 | 10:58 AM
Kredz28's Avatar
Another vote for assembly lube here...cant go wrong..carefull not to nick the bearings when you slide it in, and like rich said, goop that cam up real good!
Old Aug 10, 2006 | 11:38 AM
buddy95z's Avatar
I agree if this was a fresh shortblock but its not. According to Comps website (that's the cam I've got) it says to only use heavyweight oil on the bearing journals and lube on the lobes. That I also agree with if I were using new lifters but I'm not, I'm reusing my stock ones which are already plenty broke in. Also, since you don't break-in a roller cam the same as a flat tappet I'm not sure I see the need for lube. I'm not trying to cut expenses guys just want to hear everyone's input and good reasoning as to why and these are my reasons for questioning it.
Thanks again for all input.
Old Aug 10, 2006 | 11:39 AM
buddy95z's Avatar
Just curious what you think happens in your motor when its 90 degrees outside and your cars parked in the sun for 8 hours when your in work? No disrespect just getting you thinking.
Old Aug 10, 2006 | 12:11 PM
Javier97Z28's Avatar
Moderator
I've used assembly lube on 5 or 6 cam installs now. Each time has gone flawlessly, new builds old builds.. didn't matter.
Why mess with proven success?
Old Aug 10, 2006 | 12:29 PM
Kevin Blown 95 TA's Avatar
The assembly lube we're talking about is different than the moly paste that you use on a flat tappet cam lobe. It is more like a heavyweight lube but it clings and doesn't run off like regular heavy oil.
Old Aug 10, 2006 | 01:01 PM
SSCamaro's Avatar
I use pure molly on everything and then prime it. Would be kind of hard to prime (in car, unless I have not found the secret yet) the LT1's , so, not sure how well the molly alone would protect?
Old Aug 10, 2006 | 01:12 PM
cause4panic's Avatar
Straight up molly grease here
Old Aug 10, 2006 | 01:14 PM
WS Sick's Avatar
My motor with miles on it already has everything seated and set together.
But start-up is the point where most wear occurs.
Old Aug 10, 2006 | 01:15 PM
WS Sick's Avatar
I have an old distributor shaft cut down and I use an air powered angle grinder. I pop the inake off , prime it slap the intake back on and start it.
Old Aug 10, 2006 | 02:50 PM
Mikey97Z's Avatar
Rich
Woah! Gettin a little excited there, huh.
Old Aug 10, 2006 | 03:44 PM
sleeperMULLET's Avatar
i used moly paste on the lobes and a mixture of white lithium grease and oil on the journals, it keeps the oil from running off.
