View Poll Results: Assembly lube or heavyweight oil?
Assembly lube
17
89.47%
Heavyweight oil
10.53%
Voters: 19. You may not vote on this poll
Just curious what everyone is doing when camming there stock bottom ends. Are you using assembly lube or just coating everything in heavyweight oil?
Thanks for all input. Have a nice day.
Re: Assembly lube or heavyweight oil?
Another vote for assembly lube here...cant go wrong..carefull not to nick the bearings when you slide it in, and like rich said, goop that cam up real good!
I agree if this was a fresh shortblock but its not. According to Comps website (that's the cam I've got) it says to only use heavyweight oil on the bearing journals and lube on the lobes. That I also agree with if I were using new lifters but I'm not, I'm reusing my stock ones which are already plenty broke in. Also, since you don't break-in a roller cam the same as a flat tappet I'm not sure I see the need for lube. I'm not trying to cut expenses guys just want to hear everyone's input and good reasoning as to why and these are my reasons for questioning it.
Thanks again for all input.
Originally Posted by WS Sick
Assembly lube, the heavy oil will run off on a hot day leaving you with mildly oiled bearings for the first start-up.
No disrespect just getting you thinking.
I use pure molly on everything and then prime it. Would be kind of hard to prime (in car, unless I have not found the secret yet) the LT1's , so, not sure how well the molly alone would protect?
Just curious what you think happens in your motor when its 90 degrees outside and your cars parked in the sun for 8 hours when your in work?
But start-up is the point where most wear occurs.
