ASR and SGS Switches
Old Jan 2, 2007 | 12:48 AM
Executioner2k5's Avatar
This is probly a supid question but other then taking my car the a Dealership is there any other way to tell if my car had either of these switches on it? 1997 Camaro Z28. I have the build sheet for my car but i also have an extra switch wire under my dash and it has constant power to it any one have any ideas?
Old Jan 2, 2007 | 01:31 AM
TW95Z's Avatar
For ASR a quick way is to look at the number of brake lines going to the rear brakes. Two hoses from the body to the rear axle = ASR. The other way is one ABS only sensor in the differential or ABS/ASR has one sensor on each rear wheel. What's SGS?
Old Jan 2, 2007 | 01:40 AM
SGS=Second Gear Start 97-02 camaros had a switch for that but i think it was for the Autos only
Old Jan 2, 2007 | 01:54 AM
any one have a picture of what an Camaro with ASR looks like on the axle/rear brakes?
Old Jan 2, 2007 | 05:28 AM
If you have ASR, there will be a huge ugly black box sitting on top of your driver's side valve cover. You will find RPO "NW9" on your build tag.
Old Jan 2, 2007 | 01:43 PM
nope no huge ugly black box well that eliminates the ASR what about the SGS?? ne ideas on how i can tell if i have it or not?
Old Jan 2, 2007 | 06:31 PM
GMRL's Avatar
Is there a switch on the dash where it should be. Or is there a blank spot like this.
My M6 Z28 has a switch for the ASR and a switch for the fog lights.
SGS could only be had with A4s
Old Jan 2, 2007 | 09:21 PM
there is a blank spot but i have a wire that has constant power to it behind my radio that has the same connector as the fog light but it has a little diff shape
Old Jan 2, 2007 | 09:23 PM
my car is an A4 btw
Old Nov 22, 2011 | 09:21 PM
MikeR's Avatar
Re: ASR and SGS Switches
I'am in need of a ASR switch for my 2002 Z28.
Old Nov 23, 2011 | 12:39 PM
Please use the "Parts Wanted" forum when searching for parts.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
