ASR light on dash
Old Feb 22, 2010 | 04:31 PM
teamstream's Avatar
ASR light on dash
Gotta silly question, but whats the ASR light mean? its on in my 94 Z.
Old Feb 22, 2010 | 05:02 PM
Guest47904's Avatar
Guest
That was going to be traction control which was later canceled for 94. I believe ASR meant Automatic Slip Regulation.
Old Feb 22, 2010 | 05:04 PM
mudbone's Avatar
ASR is "Anti-slip Regulation". In other words, traction control. In some 4th-gen F-bodies, there is a fairly crude version of traction control that automatically reduces the throttle to control wheel slip. When you press the switch to turn ASR off, another light indicates "ASR off" status.
Old Feb 22, 2010 | 05:16 PM
teamstream's Avatar
well, my car is a 94 z, but a few weeks ago i found out that the opti was a 95+ style. did they change something with the traction control between years? i havent found a traction control button if its suppose to have one.
Old Feb 22, 2010 | 05:24 PM
Guest47904's Avatar
Guest
It didn't have any. The light or the spot for it was there only because they thought it would be used but was later dropped.
Old Feb 22, 2010 | 05:31 PM
teamstream's Avatar
so in order to get it to go away just pull the bulb huh?
Old Feb 22, 2010 | 05:47 PM
According to the 94 Camaro Owner's Manual, ASR = Acceleration Slip Regulation. The Camaro White Book confirms that, and correctly shows that ASR = RPO NW9 was not available until 95. GM had every intent to put ASR (Pontiac called it "TCS") in the 94 F-bodys, but it never made it into production until 95.
If the vehicle had ASR, it would have NW9 on the build tag, an "ASR" button on the console near the cig lighter, and a large, ugly black box on the driver's side valve cover, with throttle cables entering and leaving.
1996LT1Z28
Apr 14, 2015 07:15 PM
dluna333
15
Mar 13, 2015 12:30 PM
edman
Jan 25, 2015 02:41 PM
1996LT1Z28
Jan 14, 2015 08:09 AM
fpete1992
Dec 11, 2014 03:51 PM
