ASP pullyes squieling?
Old Mar 23, 2004 | 01:50 AM
BlackBird97's Avatar
I just installed a set of ASP pulleys on my car, whenever I am at a higher RPM they squeal like all hell for a moment. What do you think is causing this? Thanks.
Old Mar 23, 2004 | 07:07 AM
agent z28's Avatar
I have the ASP pulley set, though I'm only using the crank pulley. Its never squealed. Have you checked the obvious things ? Did you install the proper short belt ? Another possibility is that your belt tensioner is worn and not able to accomodate the shorter belt. Is anything leaking onto the serpentine belt system ?
DomesticViolence
Aug 8, 2002 11:32 PM
Z28 97'
Aug 4, 2002 09:43 AM
JDohn2001
Jul 26, 2002 05:57 PM
JDohn2001
Jul 26, 2002 08:14 AM
