Arrrggghhhh @%@$^ Holley
Old Feb 5, 2006 | 02:10 PM
Heatmaker's Avatar
Advanced Member
I can't seem to gigure out my when my throttle pedal is released the blades say open about 1mm... and the bracket wont set on the idle screw... so instead of idling at 800 like it should... it will idle 1200-1400... if I rev the carand release of fthe pedal it will go down a bit to about 1000... but it's not seting on the idle screw... has anyone else had this problem? and how have you fixed it?
Old Feb 5, 2006 | 02:26 PM
luckyou03's Avatar
Re: Arrrggghhhh @%@$^ Holley
I have a holley and heard about this problem so i smeared a thin layer of oil around the inside where the blades close. I've never had it stick once.
Old Feb 5, 2006 | 04:02 PM
12SCNDZ's Avatar
Unhook your cruise control cable (from the t-body) and try it. I had to adjust my cable before mine would close.
Frank
Old Feb 5, 2006 | 04:08 PM
97 RedSS's Avatar
Does it have alot of gunk around the blades? Id clean it real good and maybe take some real fine grit sand paper to where it closes..
Cody
Old Feb 5, 2006 | 04:43 PM
Angelis83LT's Avatar
I have that problem every now and then.. there should be a plastic cam on the passenger side of the carb. gently push it down and it wil unstick... you probably have some buildup
Old Feb 5, 2006 | 08:29 PM
The Engineer's Avatar
It could be the linkage adjustment interfearing with the idle and not the TB its self. I have the Holley 58mm TB, but I carefully adjusted the end-stop, linkage and TPS before I ran it. Also, I have the ASR servo to deal with which I adjusted first. Everything with my Holley 58mm works great! PM me if you have any questions.
http://www.cardomain.com/ride/2189634
Potent77
Mar 16, 2022 12:13 AM
RUENUF
Mar 13, 2016 03:39 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
