Opinions on lifters?
With my new heads/cam on the way in a few weeks I'll be replacing my lifters this time around.
Comp R's with all these retainer problems reported are out of the question.
Morel's are out of my budget.
That leaves..
OEM kit part #12371042, 16 #17120735 lifters - $181
Comp OEM style - $200
Sealed Power lifters OEM style - $9 per lifter - $144
I imagine the Comps are the best way to go here?
What the actual difference amongst the 3?
That leaves..
Re: Opinions on lifters?
There is always these:
http://store.summitracing.com/defaul...=egnsearch.asp
Not too bad for under $12 each.
But I don't recommend anything for stock lift if your cam has a higher lift. Many here have said that they have used the stockers with higher lift but I feel it's just a matter of time before they are over stressed. Not sure just a guess.
In that case I would recommend these.
Oh yeah. Since 1975, never had a Crane product let me down.
GM PART # 17120735
CATEGORY: Engine Valve Lifter
PACK QTY: 8 CORE CHARGE: $0.00
GM LIST: $48.94
OUR PRICE: $24.47
thats off of gmparts direct, wtf? does that mean you can get a set of lifters for only 50 bucks?
also will stockers be ok for a hotcam?
GM LIST: $48.94
OUR PRICE: $24.47
I thought we don't use alignment bars?If I'm gonna spend ~$500 on lifters, I'm getting Morels. JMO
Probably your stock,existing lifters will be fine after a Good inspection. Look at the botton "ears" for crack's and wash the outside real good and check the rollers for slack and rough spots. Look at the brg axle and make sure it's tight and no cracks around them.
Do not submerge lifters in solvent,just rinse off the outside and blow dry.
I have used 100,000 mile factory lifters on a pretty good size cam with 150 seat and 350 nose pressure and they were fine. Make sure your springs are up to the pounding as that's were most of the horror stories ya hear about lifters-- To little spring pressure.
Hey--- If ya just gotta get rid of some money get rid of it over this way.
Originally Posted by Cmr0z28
"For use with standard GM alignment bars."
I figure it's $200 in security in a $3k setup
