arp oil pump stud
Old Dec 27, 2005 | 06:05 PM
Ws6Envy's Avatar
arp oil pump stud
today i mounted my oil assembly and when i torqued down the oil pump i noticed that the stud seemed rather short only topping the oil pump by about an 3/16 of an inch. the oil pump nut is torqued down to 65 ft/lbs and the stud only reaches 1/2 way into the nut.
does this sound right, or should i get the longer oil pump stud?
Old Dec 27, 2005 | 06:10 PM
Dave89IROC's Avatar
Re: arp oil pump stud
needs to be longer
Old Dec 27, 2005 | 06:11 PM
Ws6Envy's Avatar
thanks man
Old Dec 27, 2005 | 06:34 PM
Admiral94's Avatar
As a rule of thumb the stud should reach at least all the way through the nut for proper clamping.
Old Dec 27, 2005 | 09:51 PM
Ws6Envy's Avatar
it makes sense....thanks for the replies
Old Dec 27, 2005 | 10:19 PM
MachinistOne's Avatar
Threads go all the way through the cap, make sure you are not putting them in too far.
Old Dec 28, 2005 | 05:22 PM
Ws6Envy's Avatar
yea, i went to the parts store and swapped out the std.length oil pump stud for the longer one....worked perfect.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
