arp oil pump stud
arp oil pump stud
today i mounted my oil assembly and when i torqued down the oil pump i noticed that the stud seemed rather short only topping the oil pump by about an 3/16 of an inch. the oil pump nut is torqued down to 65 ft/lbs and the stud only reaches 1/2 way into the nut.
does this sound right, or should i get the longer oil pump stud?
