ARP Head studs Not Sealing
Old Jun 15, 2008 | 03:37 PM
  #16
ShownomercyZ28's Avatar
So can I just use regular teflon tape on all the head bolts?
Old Jun 15, 2008 | 06:01 PM
  #17
Kevin Blown 95 TA's Avatar
I always use the GM coolant system sealing tablets in my car when I do the engine and those seem to prevent any leaks. My car runs pretty cool too. I used the ARP sealant with ARP studs. When I put the studs in I had sealant on the threads and inside the threaded holes too before I screwed them in. After I screwed them in, I wiped up all the excess then put the gasket on. I guess it doesnt works so well for some people - it looks just like teflon based pipe dope to me.
Old Jun 15, 2008 | 06:56 PM
  #18
cnorton's Avatar
It works like regular pipe dope. I buy pipe dope at Home Depot for a somewhat better price per ounce than ARP Sealant. Works fine.
Old Jun 15, 2008 | 09:34 PM
  #19
Speed Density's Avatar
I had a leaking problem with one of mine.
I just used a good amount of teflon paste and it looks to be mint.
Old Jun 16, 2008 | 07:27 AM
  #20
526 SS 96's Avatar
Yes. 4-6 wraps should do it. Remember, there is some technique to using teflon tape. It's important to wrap the tape so it does not unravel as you are tightening your bolt.
jasonisdn: Yea, those are important .
Old Jun 16, 2008 | 08:24 AM
  #21
1982z28with18s's Avatar
Originally Posted by MachinistOne
Step one is to throw that ARP sealant crap in the garbage, step two is to buy Permatex #2 non-hardening thread sealant.
I don't know how many people I have told to use this and they didn't listen. They used the ARP stuff and the studs leaked. #2 has worked great for us on many motors and never had one leak.
Old Jun 16, 2008 | 04:44 PM
  #22
95Blackhawk's Avatar
Just an update, I teflon taped the 2 that were leaking and no more leaks.
Now I am going to have to alway be checking the ones inside the valve covers though for leaks...
Kinda sucks.
Old Jun 16, 2008 | 06:54 PM
  #23
jasonisdn's Avatar
we all learn something new everyday. ANYONE that says they know it all, is a liar.
Old Jun 17, 2008 | 04:27 AM
  #24
SS Joe's Avatar
Have they changed the ARP thread sealant lately? I have used it for years, on studs and bolts, with no issues.
Old Jun 17, 2008 | 12:02 PM
  #25
fast 93 z's Avatar
I have had problems over the years getting studs to seal on LT1 engines. Have tried everything in the book. Permatex # 2, ARP sealant, teflon paste, teflon tape, aviation rtv, Holamar, and TA-29. TA-29 works the best from my experience.
I have noticed milder motors do not have that problem as bad as high horsepower high reving LT1's. I think the block moves around at high rpms and causes them to leak.
Tony Shepherd
Old Jun 17, 2008 | 05:39 PM
  #26
gatorhead's Avatar
I agree with Shep! I have seen the same exact things and have no real reason as to why the failures. It could be assumed that heat cycling plays a role in it and that they should be retorqued even though it is said to not be necessary. I have seen them leak down over time as well as loose coolant. I avoid studs on the heads at all costs. Now on the other hand ARP head bolts FTW! I use ARP stud kits in the bottom with absoultely no issues, it is only on the heads.
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
May 27, 2015 09:53 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
