ANyway to find out what is causing knock retard?
Old Mar 14, 2004 | 08:33 PM
neat's Avatar
Ok, my tuner (PCMforless) just got ahold of my data logs and said I have a TON of knock retard. My car has GM LT4 roller rockers, shorty headers, no cats, magnaflow catback, and is an 11:1 compression 383.
I tightend the rockers using this method:
http://www.fearlessperformance.com/installmain.htm
Anyone think the rockers are too loose, causing false knock?
I don't think the exhaust could be triggering the false knock either.
Here in Utah we only have 91 octane gas, but we are also 5,000 ft. above sea level. At such a high elevation I assumed 11:1 compression and 91 octane would work fine. Was I wrong? Do you guys think I should get some 100 octane the next time I fill up and see if it goes away?
How do I check to see if I have a faulty knock sensor?
Lastly, if it is real knock, what are my options?
Old Mar 14, 2004 | 08:53 PM
n2oCamaro's Avatar
You can determine false knock by running a few gallons of 100 octane unleaded with as little pump gas as possible. Log some data and if there is knock retard, its false. Some causes include exhaust hitting/rubbing somewhere, exhust leak at the header flanges and rocker chatter (self aligning rockers are bad about this.) With 11:1 compression, 91 octane is kinda pushing it in my opinion.
Old Mar 15, 2004 | 01:09 AM
neat's Avatar
Thanks, any other idea's?
Old Mar 15, 2004 | 12:52 PM
llafro's Avatar
I looked at your website. It says you have a 226/226 cam. With 11:1 compression, you should be fine. That's only marginally more than stock (which is 10.5:1). Given the bigger cam, I'd say your dynamic compression ratio might actually be similar or less than stock. 91 octane shouldn't be a problem for you.
Old Mar 15, 2004 | 07:15 PM
n2oCamaro's Avatar
The specs I see says a hot cam for his car. But either way there is not alot of overlap, which is what bleeds down compression. Running 91 in a stock engine would be pushing it. I am not saying you can't do it, but it would be much better with 93.
Old Mar 15, 2004 | 08:11 PM
neat's Avatar
Gasoline is a moot point, as there is only 91 here.
The website is a tad out of date, my new cam is 232/242, .565/.576 on a 114.
maybe2fast
Mar 16, 2015 11:59 AM
squarehead
Nov 21, 2014 08:02 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Nostang 96z
Aug 31, 2002 12:01 PM
