Anything else possible besides IAC?
Old Oct 19, 2005 | 07:56 PM
djm_e22's Avatar
When I press in on the clutch my car will not go back down to idle until I come to a complete stop. Now I checked the IAC with a meter and did exactly what shbox shows to do on his site, and everything is good. Would this mean it is not dirty and also not sticking? If so is there anything else that can cause my car to do this? Thanks for any help.
Old Oct 19, 2005 | 08:27 PM
Crazy95Z's Avatar
Re: Anything else possible besides IAC?
How high does it hang? Mine sticks at 1500 until a complete stop and has done that since my dad bought the car new in 1994. Later
Old Oct 19, 2005 | 08:32 PM
Alvin@pcmforless.com's Avatar
Sometimes the TB shaft and hardware wears out.. Mine is liket his and you can actually push on a part of the shaft and the idle comes down.. kinda hard to explain.
Old Oct 19, 2005 | 09:29 PM
djm_e22's Avatar
mine hangs around 2000
Old Oct 19, 2005 | 09:47 PM
The PCM is programmed to keep the idle high until the VSS reads "0"...... unless its an unreasonable high RPM, its supposed to work that way. 2,000rpm would be excessive.
Old Oct 19, 2005 | 10:37 PM
slimdawson's Avatar
Yep. It's the rpm vs speed table or something like that. I edited mine to idle lower, quicker. It still stays revved on occasion(mostly open loop it seems) until I come to a complete stop. I just haven't had the opportunity to go back and tweak it some more.
Old Oct 20, 2005 | 09:45 AM
OBE1 95Z28's Avatar
When I cleaned my TB, my RPM started hanging. I dabbed some oil on the butterfly shaft where it meets the body and that cured the hanging issue.
Old Oct 20, 2005 | 11:40 PM
BLK96Z28's Avatar
Just curious. How much for a new IAC? Who carrys them besides GM?
Old Oct 21, 2005 | 09:27 AM
OBE1 95Z28's Avatar
Thanks to Shoebox: GM P/N 17113188 $49.50
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
tdigger9899
Sep 7, 2015 10:56 AM
lt1matt
Mar 21, 2015 07:35 PM
