anyone who installed there LT1 SCANMASTER USING with ADL PORTS
Old Apr 13, 2005 | 06:35 PM
detroit1994z28's Avatar
I just bought a ;t1scanmaster and bought adl ports with a cigg lighter adaptor from andrews electronics. does anybody or can anybody please tell me how to wire these wires. I hooked everything up according to andrews detail and nothing works. On my scanmaster I have three wires a red,white, black which wires go where. - Anybody please help. I have the obd1 computer. - Mike
Old Apr 13, 2005 | 06:53 PM
Dave89IROC's Avatar
Re: anyone who installed there LT1 SCANMASTER USING with ADL PORTS
adl?
Old Apr 13, 2005 | 07:02 PM
aldl ports -
Old Apr 13, 2005 | 08:40 PM
OBE1 95Z28's Avatar
From Brent Franker's webpage:
For the connection to the ALDL wires, I used red Scot-Lok (I think that's the name of them connectors. They allow splicing into wires without having to cut any wires. They make splicing very easy when working in a tight area such as this! On my 96SS, the connection is as follows: The ScanMaster RED wire is the power wire and gets connected to the ORANGE wire on the ALDL connector in location #16. This is a nothing more than a power feed from the cig lighter, fuse #11. The ScanMaster BLACK wire gets connected to the BLACK wire on the ALDL connector in location #4. This is your ground wire. The ScanMaster WHITE wire (data wire) gets connected to the TAN wire on the ALDL connector in location #9. Keep in mind, these are locations for a 96 with an OBDII connector so if you have a different year, yours may be different.
Old Apr 13, 2005 | 11:59 PM
You don't need to connect it using an ALDL connector.... only the white wire actually has to attach to the tan wire in the ALDL connector. I spliced a wire onto the tan wire at the back of the ALDL connector, and used a single-pin connector so the ScanMaster could be removed. Do the same with any 12V source and ground in the area.... they do not need to be the ones in the ALDL connector.
You might find this helpful....
http://members.aol.com/InjuneerZZ/ScanMast.htm
oldschool
Feb 9, 2016 09:21 PM
bandit383lt4
Dec 21, 2014 09:12 PM
thenewkid
Nov 29, 2014 04:54 PM
