Anyone using this crank as a stock replacement?
Old Jan 3, 2004 | 03:16 PM
  #16
ChevyIron's Avatar
Rob sent you Email.
Old Jan 4, 2004 | 03:43 AM
  #17
slopokrodrigez's Avatar
Hey Rob, I found some info I think you might find interesting at :
http://www.automotiverebuilder.com/ar/ar99928.htm
It says:
CRANKS
350 - The crank for the LT1 looks just like the one in the late 350 and has the same casting number 14088526, but it’s balanced for the lightweight pistons that were installed in the LT1. In fact, if you are short of LT1 cranks and don’t have a balancing machine in your shop, you would be better off using a crank from a 305 instead of a 350 because it’s actually closer to the balance specs for the LT1 crank.
Obviously that does not apply to your case but this may be of some help regarding balancing:
HUB AND BALANCER
The balancer is a two-piece assembly with a pulley that bolts onto the hub. Separating the two made it easier to install the Optispark distributor on the assembly line and out in the field. The holes in the hub are offset, so the balancer only fits on it one way, but there’s no keyway in the hub to index the hub on the crank. This shouldn’t be a problem unless the damper was drilled at the factory to "trim" the final engine assembly.
If it was drilled a lot to compensate for an engine that was out of balance, you could end up with a shaker, depending on how everything stacked up with the remanufactured engine compared to the original engine. If you encounter a balance problem on a remanufactured LT1, try rotating the balancer assembly on the crank 90° at a time to see if it eliminates the problem.
This clearly indicates that some cranks and their balancers were matched and the balancers in those cases are not neutral. Both the balancers on the engines I have are like he said and drilled like crazy.
Sorry it's long but I hope it helps you and provides some info for others.
Dave
Old Jan 4, 2004 | 09:07 AM
  #18
Thanks, Dave. I had already gone back and read that stuff on that page to refresh my memory. Looks like I am going to take up ChevyIron's offer on the crank. I did not expect to get an offer like that. Will see how that "turns" out.
Old Jan 21, 2004 | 05:36 PM
  #19
Update
ChevyIron graciously offered me a crank and I paid the shipping. I got it today and the shop says it only needs a polish. That's pretty awesome.
Where can you get a response like that from people you don't even know? Truly amazing.
Old Jan 21, 2004 | 06:36 PM
  #20
ChevyIron's Avatar
No problem Rob I just glad it worked out for you.I grateful for all your helpful how to do pages and your advice.Its my way to help a fellow board member out Be well David
Old Feb 3, 2004 | 03:08 PM
  #21
Latest update:
Had the engine running for a couple days (fired right up the first time) and took the car out for the first time today. All seems normal.
It's been a while since I had an engine down to bare bones. I hope the sucker stays together, LOL!
Thanks for the "organ donation", ChevyIron!
Old Feb 3, 2004 | 04:04 PM
  #22
ChevyIron's Avatar
I Very happy its working out for you,Happy MOTORING ROB cheers.
David
Brandon Wittmer
Dec 20, 2014 09:51 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
GigaMp3z
Feb 20, 2003 02:57 PM
mjcent922
Jul 27, 2002 12:42 PM
