Anyone use factory plug wire routing on Pacesetter LT's
Old Jan 5, 2005 | 03:34 PM
wicked_95z's Avatar
Has anyone ran their plug wires in the factory locations with pacesetter longtubes
Old Jan 5, 2005 | 04:36 PM
BamaZ28's Avatar
Re: Anyone use factory plug wire routing on Pacesetter LT's
I did use stock routing, and then I learned my lesson 3 burnt wires later. OVC all the way.
Old Jan 5, 2005 | 05:30 PM
StickMaster's Avatar
I have routing in the stock locations right now with magnecores, no problems until a week or so ago (put them on ummm 2 months ago?) i popped the hood at night and could see some arching when i reved it...but i was pretty drunk so ill check again and let you know. BTW stock routing is a bitch to do especially on the passenger side
Old Jan 5, 2005 | 05:34 PM
zx1216's Avatar
i have mine in the factory positions with out any problems that i know of, although i will probably get ovc wires this spring.
Old Jan 5, 2005 | 09:56 PM
dirtybird96's Avatar
I have mine in the stock location. I burnt 2 wires but it was my bad for not re strapping them.
Old Jan 6, 2005 | 09:31 AM
95zzz28's Avatar
i am using factory locations. i just put boot covers on ALL the wires. only problem to date was a burnt wire on #5(i believe, maybe #6). that was after a long 1.5 hour drive. this wire was right next to the primary(by the flange)though.
other than that, no problems, and running like a champ. even when i use nitrous
Old Jan 6, 2005 | 05:06 PM
FryedClutch's Avatar
i used stock routing because i had the some taylor thundervolts but now i only have 6 thundervolts and a brand new set otvc wires so i also learned my lesson
Old Jan 7, 2005 | 02:03 AM
DarkKnightZ28's Avatar
I used my stock routing and the only one I had problems with is the number 5 or 6 wire (3rd one back on driverside), it was touching the header but i put some thermal sleeve on it and so far it's been fine. It's time though for a wire change so I want to go OTVC also. Any suggestions for OTVC wires, I want to get them in either red or black.
Old Jan 8, 2005 | 12:31 AM
Sunsceamer's Avatar
I did stock wiring and #6 will get you.
I got about 30 miles to the boot. Just get the ovc wire and forget it.
Old Jan 8, 2005 | 06:36 AM
wicked_95z's Avatar
I was using the accell wires for an OTVC routing but they are a year and a half old and are starting to arc so I was going to use a factory set of wires for now and was just waondering if there were any tricks to make them last. I think my setup may work. I pulled them away from teh headers and ziptied them to he motor mounts and then ran them forward so we'll see
Old Jan 8, 2005 | 10:14 AM
Hybrid86Z's Avatar
i spend the extra 100 bucks and got Taylor OVC wires w/ the brackets and everything.....i did it right the first time and I'm happy as hell, no problems at all
Old Jan 9, 2005 | 05:29 PM
atljar's Avatar
Ive always run stock locations with both hookers and pacesetters and havent ever had issues. On the drivers side tuck everything against the block under that heat shield. On the passenger side route the back cyls behind the oil dipstick and zip tiw them down. Then run everything under the accessory bracket up front and to the opti. All good.
Old Jan 10, 2005 | 05:16 PM
Franks95Z28's Avatar
Question Re: Anyone use factory plug wire routing on Pacesetter LT's
Where do you get OTVC Wires??Who makes them and do you have a Part#?
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
Jazsun
Dec 29, 2014 12:14 PM
