Anyone try this elbow on their single plane?
I ran across this elbow that is built for the LSx motors and I am wondering if anyone has had any luck at fitting one on an LT-1 without extensive modification??? The single plane manifold may affect fitment as well as I believe there is some height differences between say an Accel Pro-Ram and an Edelbrock Victor EFI intake.
www.intakeelbows.com/ls1elbowgrey.htm
Also, although it IS designed for a (cough!) FORD (cough!), I thought this looked interesting as well.
http://www.sullivanperformance.com/Y.../tbadapter.htm
(Note: This is for a F.I. motor that I am putting together so there may be a few less concerns using these in my application than in a normally aspirated application)
This billet adapter will allow you to run the Sullivan elbow and Cobra TB with a stock IAC valve.
http://www.powergridinc.com/iac.asp
Intakeelbows.com no longer produces an adapter elbow that will accomodate a dual bore LT1 style throttle body.
Do a search for my name on here, I have an intakeelbows elbow with a monoblade on my car.
David
David,
What were the results of your setup?
RX Speed Works
Oct 1, 2015 10:19 PM
cmsmith
Sep 14, 2015 09:25 PM
