Anyone try this elbow on their single plane?
Old Mar 18, 2007 | 02:05 PM
Boosted_Z28's Avatar
I ran across this elbow that is built for the LSx motors and I am wondering if anyone has had any luck at fitting one on an LT-1 without extensive modification??? The single plane manifold may affect fitment as well as I believe there is some height differences between say an Accel Pro-Ram and an Edelbrock Victor EFI intake.
www.intakeelbows.com/ls1elbowgrey.htm
Also, although it IS designed for a (cough!) FORD (cough!), I thought this looked interesting as well.
http://www.sullivanperformance.com/Y.../tbadapter.htm
(Note: This is for a F.I. motor that I am putting together so there may be a few less concerns using these in my application than in a normally aspirated application)
Old Mar 18, 2007 | 02:34 PM
T/A KID's Avatar
intakeelbows.com makes an LT1 setup, Madman on here has one on his LT1 Twin Turbo setup
Old Aug 22, 2007 | 01:51 PM
RRR's Avatar
RRR
I like the no clearance issues. wonder if it would be the same for an lt1? I'll try e-mailing the guy.
Old Aug 22, 2007 | 02:58 PM
<Puck>'s Avatar
The ford part uses a totally different IAC, which I'm sure has different wiring that will not play nice with a stock computer.
Old Aug 22, 2007 | 03:14 PM
thesoundandthefury's Avatar
This billet adapter will allow you to run the Sullivan elbow and Cobra TB with a stock IAC valve.
http://www.powergridinc.com/iac.asp
Intakeelbows.com no longer produces an adapter elbow that will accomodate a dual bore LT1 style throttle body.
Old Aug 22, 2007 | 04:50 PM
FASTFATBOY's Avatar
Same mount flange as most single planes a 4150 style, too low in the front to fit a Edelbrock 2925, will hit the coolant crossover.
Do a search for my name on here, I have an intakeelbows elbow with a monoblade on my car.
David
Old Aug 22, 2007 | 05:30 PM
The front coolant crossover of course can be removed:
If I'm not mistaken, I believe Brett Bauer did the conversion on that one.
Old Aug 23, 2007 | 12:00 PM
Vicious95Z28's Avatar
This is the only way I'd do it, w/o the coolant crossover. I wonder what the $ on this would be. FastFatBoy has a good looking setup. I love it aside from the coolant crossover, but you can hardly see it on his car unless you are really looking for it.
David,
What were the results of your setup?
marlar98
Oct 21, 2015 02:02 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
cmsmith
Sep 14, 2015 09:25 PM
Slayer
Aug 17, 2015 03:55 PM
