Anyone take their alt. belt off at the track???
Re: Anyone take their alt. belt off at the track???
I have been told that wiring a switch into the main hot wire going into the alternator will give you much of the same effect as unhooking the belt. That is something you could very easily do on the street, and then turn it back on.
Originally Posted by 96WS6TA
I did it before my electric water pump and it definatly makes a difference. 2-3 tenths. It is amazing how much more responsive the engine is. Also to anybody who says its stupid because you are "lieing" to yourself, that has got to be the dumbest thing I have ever heard. So I guess slicks are stupid too, because you never run your car that way on the street, or race gas, or uncapping the exhaust, or unhooking your front sway bar, or maybe letting a little air out of the tires or installing a fresh set of plugs. These are all little things you can do at the track to gain a little hear and a little there. Some of these tricks work for some and not for others. None of them are stupid. After all, the idea at the track (for most people) is to go as fast and as quick as possible. If you just want to see what your car will do in street trim, leave it alone. I won't do the belt thing with the electric wp, but I wouldn't hesitate to do it if I still had my stock wp on.
I wouldn't do it anymore with the electric water pump because it is placing more load on an already heavly taxed battery. There is going to be a point where the reduction of voltage is going to start causing problems with things like the ignition system, fuel pump, etc. This will vary depending on battery condition and the load on the battery. I just wouldn't feel comfortable doing it with the extra load of the waterpump. Would it make a difference? Don't really know.
Originally Posted by Firehawk_Dude
And how does this work???
My guess would be that if the alternator is putting out electricity that it is putting a load on the belt, thus robbing horsepower. This is my understanding of this, someone correct me if I am wrong.
If you switch off the field windings in the alternator it will still turn, but it won't put any load on the engine since it's not producing any power.
From a bolt on pulley to no belt i gained .04 in ET and about .6 in MPH on the SAME day and nearly identicle 60' (1.689 to 1.687 or something like that). However my best runs were made with an ASP replacement balancer. I acutally was faster with it on than with the belt off.
Load on the alternator however, does NOT affect how hard it is to turn over. A higher amperage alternator will take up more HP as the rotor inside it is heavier. Alts work on the principle of induction. Spin a magnet inside a field of coils and you get AC current. There is no way that the armature knows the load on itself. After the AC current is rectified, it goes through a voltage reg which will control your output. If you need more current, it will feed more voltage into the rotor making it a stronger magnet. However, as you make the north field stonger, you also make the south equally strong. The forces are going to cancel each other out negating the fact that its producing more amperage.
Basically what i am saying is, by outputting voltage, you arent making it harder to turn over than if you had no voltage flowing from it. The gains are simply from reduction of rotating mass when you remove the belt.
Even though i posted about the alt. belt i was also concerned with all the other pulleys on the belt since it is a street car i will be running. I think I will see a noticable gain with the belt off. As long as i keep the battery charged between runs, i should have no troubles.
Brandon
Brandon
Louey
Pacific
Aug 7, 2015 01:47 AM
Louey
Pacific
Jul 21, 2015 10:06 PM
