Anyone running Crower Cam?
Old Mar 6, 2004 | 03:13 PM
SiK95's Avatar
Anyone running the cam below? If so how is it working for you?
Crower Stage 3
Crower Camshaft Specification Card
ADVERTISED CAMSHAFT SPECIFICATIONS:
INTAKE: Duration: 277º Lift: 0.534 Clearence Hot: 0
EXHAUST: Duration: 286º Lift: 0.549 Clearence Hot: 0
The specifications listed above are based on a rockerarm ratio of 1.5 IN
1.5 EX
RECOMMENDED VALVE SPRING INFORMATION:
Part # 68304 Single X Dual Triple
Approximate spring pressure: valve closed: 105/115 LBS.
valve open: 315/325 LBS.
The information below is for degreeing cam only. Correct only at .050" tappet lift.
INTAKE
Opens: 3.0 BTDC
Closes: 43.0 ABDC
EXHAUST
Opens: 54.0 BBDC
Closes: -2.0 BTDC
LOBE SEPERATION
114º
Duration at .050"
Intake: 225
Exhaust: 232
LOBE LIFT
Intake: 0.356
Exhaust: 0.366
Amshnock
14
Jan 18, 2015 11:47 AM
1775.Z28
Jan 11, 2015 10:51 AM
Queens94z28
Nov 20, 2014 06:03 PM
Don 97 SS
Jul 11, 2005 08:50 AM
