anyone running 1.65 rollers?
Old Feb 1, 2005 | 10:32 PM
ftransam1's Avatar
Any lt1 guys running 1.65 rollers under stock valve covers? If so what minor modifications did you need to get it to work? Also what type of rollers did you use?
Old Feb 1, 2005 | 10:47 PM
Dave19yz28's Avatar
Re: anyone running 1.65 rollers?
does anyone make 1.65 ratio rocker arms?
Old Feb 2, 2005 | 11:19 AM
ftransam1's Avatar
Just about everyone makes 1.65 rollers. Comp, Crane, Harland Sharp etc. Just want to know if they will fit under stock valve covers. Then I'll have a .574/.594 lift which would be nice with my heads
Old Feb 2, 2005 | 11:26 AM
Formula_one's Avatar
A friend of mine is running 1.65s with stock valve covers. There isn't any modification needed other than what is needed to run 1.6s (either gutting the inside of them or bending the insides a little to fit between the rockers).
Old Feb 2, 2005 | 11:36 AM
TransAm2k4's Avatar
Where do you get these 1.65?? what cam and heads you running? I'm curious because i'm looking into it my self. What is the real benefit of xtra lift? Like .050 extra lift. I have AFR 190 heads so i think i might support the extra lift.
1775.Z28
Jan 11, 2015 10:51 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
