Anyone run aftermarket rockers with stock valve covers?
Old May 10, 2005 | 12:44 PM
96speed's Avatar
I had to cut the valvecover (vc) supports to make enough clearance for my comp promag rockers. I've been fighting leaks ever since. I've tried to torque the vc down more and more but leaks just the same.
Anyone figure out a way to stop the leaks?
Ryan
Old May 10, 2005 | 12:52 PM
klpps's Avatar
Re: Anyone run aftermarket rockers with stock valve covers?
taller valve covers....
Old May 10, 2005 | 01:03 PM
sssalah's Avatar
LT4 composite valve covers, worked for me without modification. You could've only trimed the supports, no need to cut them completely to clear the promagnums.
Old May 10, 2005 | 02:29 PM
How much did you hack out to fit the Pro Magnums in? All I had to do was take the web off on one side of each support tube. No leaks at all.
Old May 10, 2005 | 02:33 PM
96speed's Avatar
I removed the webbing and the tubes, regretfully. Would like to avoid buying new valve covers. Might have to go with some new stockers...
Ryan
Old May 10, 2005 | 02:43 PM
WestCoast96Z28's Avatar
Doing the same thing soon. Anybody have pics of where and how much to notch the webbing?
Old May 10, 2005 | 03:01 PM
Just cut away the web on one side.... do NOT remove the tubes. Check Shoebox's Tech Pages for photos. You also have to tweek the baffle for the PCV vent tube connection, and I believe he has that how-to on his pages.
http://shbox.com/1/4th_gen_tech1.html
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
