Anyone with Pacesetter shorty's
Old Mar 6, 2004 | 04:16 PM
ChevyTuffD.A.'s Avatar
Did anyone else have the problem with the 02 sensor going into the fitting on the passenger side header. I heard a cracking noise as i was tightening it and i took it out and the fins on the end of the o2 sensor where ground off bc there wasnt enough room inside the collector thing, there looks like there might be enough room to grind some stuff off to make some room but i wasnt sure and thought i would ask.
Old Mar 7, 2004 | 04:34 AM
craigffb's Avatar
Yep. I had the same problem with mine. If you have a Dremal you can that to take care of it fast. They have a cutting/grinding bit. Kinda looks like a long gear if you know what I mean. I also had to cut the air injection tube fittings down a bit to get them to seal up right. If you have any questions drop me an e-mail and I can probably help out.
GREEN3112
Feb 10, 2019 09:19 PM
football4life
Oct 4, 2015 07:48 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
colts0455
Jul 28, 2015 11:28 PM
