anyone not happy with XE236/242
i put down 380 rwhp with this cam& tuning (expected 400+), my best 1/4mile has been 12.7 @112 w/ 1.9 60'. most of my runs are 13.0. i dont get it.. a guy with mild ported lt1 heads and that gm847 cam went 12.1 @117 w/ 1.9 60' with stock bottom end. i saw a guy at the dyno put down 399rwhp with the 230/236. everythibng in my car is working perfectly. just wondering if anyone else is disapointed with this cam.
Re: anyone not happy with XE236/242
guy here has bout that through a stalled auto and home ported heads
stock bottom end, going through 10 bolt
You appear to be running a larger than stock displacement motor, so that's going to reduce the effect of the cam somewhat.
Also, are you running on stock heads? *scratch that, I see AFR195's...
A member of my car club just ran 12.3s with a 224/230 XE cam with a set of stock LT1 heads ported by Lloyd Elliot with big valves. He's still working on some tuning issues though so he's pretty sure there's more left in it.
Some cams do really well on stock heads, and some seem to need ported heads.
the reason for my post is im really thinking about swaping it out for a 847 cam or a cmotosports custom grind 600lift cam. i also want to pull my heads this winter and get them hand ported by lloyd or someone. i did have them flowed before i put them on and the cnc port flowed 275cfm @.600
we fooled around with the tuning for about an hour still prolly needs a little more but i dont think ill get that 20 hp. i do need to put on my 3" mandrial jethot y pipe right now i have a 2.5' assugly y pipe. i might see 10rwhp with that
i was seriously thinking about this cam (236 242 on a 111) but i think im going to go 233 239 on a 110 from cmotorsports.
my buddy has a 230 236 on a 112 i dont think its quite enough for me.
i would think you should have gotten more out of it than that.
how does that cam sound.
sorry i wasnt much help.
Formula Steve
Sep 19, 2023 08:31 AM
cmsmith
Sep 14, 2015 09:25 PM
