Anyone melt thier converter???
Old Mar 3, 2006 | 11:17 AM
roughneck427's Avatar
anyone ever melt your converter from your tune being too rich??
Old Mar 4, 2006 | 06:10 AM
Guest47904's Avatar
Guest
Re: Anyone melt thier converter???
Not from a tune but from an exhaust leak. Happened on my 99 Z71. Cost too much to replace both cats cause they are connected together so I gutted them and put on sims.
Old Mar 4, 2006 | 11:11 AM
96camaroSS's Avatar
Too much fuel will cause them to overheat and either plug up or break up. I completely blew the guts out of my passenger side cat once. Initially I attributed it to excess fueling from the blower setup. But I also discovered a bit later that the check valve for the A.I.R. fitting on that manifold was far more restrictive than the drivers side.
I suspect that many premature cat failures are the result of more than one factor IMO.
Old Mar 4, 2006 | 11:20 AM
94arcticwhiteM6's Avatar
yep i melted mine from running rich. i hollowed it out for awhile and now i have fixed the problem and added a 3 inch highflo
2QUIK6
Sep 17, 2016 02:31 PM
Slayer
Aug 17, 2015 03:55 PM
Aug 5, 2015 08:35 AM
jbert55
Aug 3, 2015 05:49 PM
detroitmuscle
Jul 31, 2015 04:21 AM
