Anyone make a straight connection (instead of a 90) between the TB & MAF?
Are there any suppliers who make an adapter connecting the throttle body to MAF senso that is not a 90 degree elbow for the LT1/LT4?
I'm looking to connect the MAF straight out infront of the throttle body.
Thanks,
Kevin
69 Camaro LT4, T56, 9" Baer Brakes, Mini Tub....................
Thanks,
Kevin
Re: Anyone mafe a straight connection (instead of the 90) between the TB & MAF?
Yes. Fernco part # 1056-33 3"x3" sewer pipe connector. $5 at your local hardware store, complete with two stainless clamps.
http://cjcfo.fbody.com/members/injun...B/N2ONozzl.jpg
Re: Anyone make a straight connection (instead of a 90) between the TB & MAF?
by going striaght to the tb does it help or is it just for looks. You would think it would help the air flow i suppose, but there could be a reason for the 90* bend, or not. Anyone know?
I'm running a LT4 in a 69 Camaro and was looking at making an air clear to use with the cowl induction hood. My thought was mounting the MAF as close to the TB then making a 180 degree turn up and back. Then connect to an air box on top of the intake.
Injuneer - Did you use Fernco to connect to the TB?
Kevin
Kevin
I'm running a similar setup to Injuneer, The Fernco connects the TB to the MAF. You may have to soak the Fernco in some hot water for a minute or so to soften it up to make it easier to install on the TB.
ChrisFrez
Jan 11, 2015 03:47 PM
Jul 4, 2005 05:00 PM
