Anyone make an aluminum Block LT1/LT4?
Old May 8, 2003 | 12:25 AM
kgkern01's Avatar
I am just wondering if anyone makes an alum 4 bolt main LT1/LT4 block? I figure it would be good for applications such as road racing and possibly drag racing for better front/rear weight distribution. I understand that it wouldn't be as strong as a cast iron block, what would be some problems w/alum over cast iron?
Old May 8, 2003 | 12:59 AM
Fastbird93's Avatar
For what I know, nobody makes an aluminum block LT1/4.
Old May 8, 2003 | 05:03 AM
rskrause's Avatar
Moderator
No one does and no one will. The LTx is a good motor, but kind of an evolutionary "dead end". If you want an aluminum engine in your 4th gen, get an LS1 car (or swap in the motor). If you have a lot of $$$ and are building something really exotic, you can get a Gen I SBC in aluminum. It's possible to adapt LTx heads and intake to a Gen I, but it wouldn't be worth it. So you are talking about a completely new setup, including an ECU (if it were to be injected) for all practical purposes.
The cast iron LT1 block is only ~100lb heavier than the LS1 aluminum block anyway.
Rich Krause
Old May 8, 2003 | 11:20 AM
kgkern01's Avatar
Just wondering.
Old May 8, 2003 | 11:58 AM
JeB's Avatar
JeB
Donovans will build you a custom block... from what I remember it was ~$4000'ish that he was wanting?
JeB
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Ringmaster72
Feb 25, 2015 03:15 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
