Anyone made some good power out a 383 or 396 stroked,using stock casting ported
Old Aug 7, 2005 | 04:13 PM
  #16
METALBEAST's Avatar
Re: Anyone made some good power out a 383 or 396 stroked,using stock casting ported
Originally Posted by ZBLKHELLRZR
396 to answer your question.
Thanks! I am getting ready to have a race shop build the bottom end of my 396. Just looking for a good stroker kit. I have already purchased some AFR 210 LT4 bare castings for the setup.
Old Aug 8, 2005 | 04:17 AM
  #17
SJBlackZ28's Avatar
Let say I went with fully ported LT1 stock casting and intake how much HPs and track time would I see with my 373 10 bolt and my fully forged motor. Here my motor setup- oh also I'll be on a 150shot wet
398 Ci .40 overbore LT4 Block
Decked/Honed
Lunati Nitrous Pistons, 4340 Crank, 6" Rods, Chromolly Rings
Crank was dynamically Balanced on the block with the flywheel and ATI Balancer.
ATI Balancer
AFR Hydra Rev Kit
Street Twin Clutch and Alum Flywheel
Canton 8qt Oil pan
High Volume Oil Pump/pickup
OBD I PCM tuned for Cam
LT1 Edit with Cable for that PCM
Laptop for tuning
Old Aug 8, 2005 | 09:11 PM
  #18
magnumv8's Avatar
I am putting down 430 rwhp 417 rwtq with my 383 with AI ported LT1 castings. I have only had it to the track a couple of times with a best of 11.86 @117. I do have a high rpm miss that I have to track down, so the times will be better once I fix that and finish with the set up on the car.
Old Aug 9, 2005 | 05:29 AM
  #19
wicked_95z's Avatar
Originally Posted by speedmiser
LE goes bigger than 2.00
http://www.eportworks.com/LT1LE3.htm
2.08 in my factory LT4 heads from Lloyd.
Old Aug 9, 2005 | 06:07 AM
  #20
hvyss's Avatar
My best friend ran ported stock castings with 2.02/1.60 valves on his 95Z 383 and 306 cam. Ran consistant 11.7's N/A and 10.80's on a 150 shot. Was running a 12 bolt Mosier though with 3.73's. I can safely say that with your setup you can kiss the 10 bolt rear goodbye. It will explode. Probably sooner than later. Seen it too many times on setups less than yours. Good luck
HVY SS
Old Aug 9, 2005 | 08:05 AM
  #21
Gripenfelter's Avatar
I'm putting out over 400rwhp from stock ported castings and a 700R4 tranny. Don't know the exact # because the opti crapped out at 5200rpm and I was already over 400rwhp. Power peak should be at 6500rpm.
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
Killer94z
Jan 13, 2015 12:06 PM
Joes96z
Dec 13, 2014 07:48 PM
