Anyone made some good power out a 383 or 396 stroked,using stock casting ported
Im just wondering if anyone has made some good power and time out a 383 or 396 USING PORTED STOCK CASTING??? I know it would not be the best but just wanted to see what people result are.
Re: Anyone made some good power out a 383 or 396 stroked,using stock casting ported
440rwhp on a mail order chip and stk water pump. They are out there it just really depends on the setup. I'm probably good for another 10-15hp if it were dyno tuned but then again it could very well be dead on or close to it.
I will be tryin out a set of 94ported heads with 2.05intake vavles and a intake to match it.It is all going to cost me 1500 but brand new heads new seats vavles.Hopin for 400,400 or somwhere close considering i will be runing a stock bore lt1.Hoping for 11's once i get a rear and some stall
Guest
Posts: n/a
Ona side note, where are you guys gettting GM casting LT1 heads and fitting anything larger than 2.00 valves. I would like to know the porter. I know AFR and other aftermarket does them, but since when can you fit these larger valves in LT1 castings.
I make 420 rwhp on my 396 with 95 Heads , 2.00 in, 1.6 ex, by CNC porter in FL. CAm is a XE 230/236 with 11.1 to 1 comp and LT headers with 58mm AS&M T Body, PCM4less tune
Mine put down the numbers in the sig before it spun a bearing... We shall see what the 383 i am getting ready to build will do...
http://www.eportworks.com/LT1LE3.htm
Hey, The American speed didnt have any LT1's, just old GM style small blocks.
